Do you have a wiring diagram for the csi elec.waterpump?
Old Aug 25, 2004 | 05:44 PM
roofo's Avatar
Post Do you have a wiring diagram for the csi elec.waterpump?
I tried the search fourms.I only got one post to read and no diagram in it.
Do I need a relay?How did you hook your waterpump up?Thanks
Old Aug 25, 2004 | 06:04 PM
atljar's Avatar
Re: Do you have a wiring diagram for the csi elec.waterpump?
http://www.akmcables.com/2ledmez.jpg
and
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Top one also has warning lights in it for if the pump goes out. Bottom one is standard install.
I just ran a standard relay. Turns on via the air pump. Draws power straight off the distribution block.
Old Aug 25, 2004 | 11:41 PM
roofo's Avatar
Thank you atljar.That was alot of help.I did not think to put in a light or switch.Maybe
I'll add those later.Jeff
Old Aug 26, 2004 | 12:08 AM
atljar's Avatar
No problem. You should like the pump, i know i do
HarleyZ28
Oct 5, 2015 06:23 AM
4586
Apr 27, 2015 06:08 AM
EdgarArmada
Apr 18, 2015 05:20 PM
lbrowne
Nov 13, 2011 04:25 PM
turbo_Z
Aug 19, 2002 10:50 PM
