Do underdrive pulleys help on a 1996 LT1
Old Jul 2, 2007 | 11:57 AM
Justino762's Avatar
I was looking into a set and i want to know if they are worth the time and money
Old Jul 2, 2007 | 12:00 PM
2000GTP's Avatar
If you were to do pulleys, I would probably only look into the ASP set and not the other "piggyback" styles out there.
Old Jul 2, 2007 | 12:22 PM
Justino762's Avatar
pulleys
Old Jul 2, 2007 | 01:45 PM
OBE1 95Z28's Avatar
Very little bang for the buck with pulleys; spend your money elsewhere.
Old Jul 2, 2007 | 01:50 PM
Justino762's Avatar
Pulleys
Sounds Good
Old Jul 2, 2007 | 03:38 PM
Mike96z's Avatar
they work for me, get the March underdrive kit with the alt and crank pulleys, this will open your car up a little bit more, make sure if your making alot of power to get a keyed crank hub though.
Old Jul 2, 2007 | 03:41 PM
CustomSSI's Avatar
If you get pulleys we'd HIGHLY recomend the ASP over anything else.
http://customssi.com/cart/index.php?...roducts_id=817
Alot of people notice a difference with that kit.. And for the price its not bad. What other mods do you currently have?
Old Jul 2, 2007 | 05:42 PM
This link has probably been posted about 10,000 times...... 0.7 peak HP, 4.4 Avg HP for a piggyback style pulley.
http://www.ws6.com/mod-2.htm
Old Jul 2, 2007 | 05:43 PM
wrd1972's Avatar
Just a teeny tiny bit. I have the ASP pulley which I like better than the piggyback pulley from March which I have used too.
Old Jul 2, 2007 | 05:52 PM
96capricemgr's Avatar
Pullies work best on cars with belt driven waterpumps because the waterpump is probably the biggest power user of the accessories. The stock LT1 WP takes 11hp to turn at 6000 engine rpms, but is not belt driven so we can't underdrive it.
Honestly IMO UD pullies on an LT1 are best left to the road racing guys to save wear on accessories more than for the freed up power. If buying a damper though might as well get the smaller and if you have a raised idle for a cam then you should not need an OD alternator pulley.
oldschool
Feb 9, 2016 09:21 PM
siguy
Nov 27, 2014 10:07 AM
94z28jbw
Sep 8, 2002 03:22 PM
