Do u have the LE1head and cam package? what do you run?
Old 07-06-2004, 02:22 PM
93transam1234's Avatar
thinking about getting this. Just wondering if i should go a difrent rout or do the heads and cam.
93transam1234 is offline
Old 07-06-2004, 02:32 PM
Moderator
Javier97Z28's Avatar
The LEwhat? Never heard of that...
Do you mean 1LE? If so that's not a heads/cam package, it's an option code mostly having to do w/ suspension.
Javier97Z28 is offline
Old 07-06-2004, 02:36 PM
1982z28with18s's Avatar
LE=Lloyd Elliot
I'm running LE1 heads but with rev valves in them, but I'm running a SMALL custom grind from Joe Overton. It's a 220/226, which is smaller than the le1 cam. Times in my sig.
1982z28with18s is offline
Old 07-06-2004, 02:43 PM
Moderator
OOps, sorry, that's what I get for not posting in the LT1 tech forum for a while hehe...
n/m me
Old 07-06-2004, 03:11 PM
Originally posted by 1982z28with18s
LE=Lloyd Elliot
Why did you go with the Joe O cam instead of the the LE? Already had it in i am guessing?
You have done just what i am plaining on doing exsept the cam.
How is the car for daily driving, any isues at all that i should know of? How is gas mileage? Stock rear still holding up? How many miles on the car?
any infor you could give me would be great
Old 07-06-2004, 03:36 PM
I got the "setup" through Lloyd, but the cam came from Joe. I got it right before Lloyd was offering his head/cam packages to everyone. I went with the smaller cam because I'm making my car a sleeper, and through stock exhaust and a high idle you can't hear the cam lope. I do lots of street racing and I don't want people to know its got a cam or heads. The cam was matched to the heads though just like Lloyds cams are matched to his heads. It dyno'd 384rwhp before tuning. I will be dyno'ing again in about a month.
Up until about a week ago I drove the car daily(80 miles/day) and I get 21-22mpg with mostly highway and 17-18 city/racing all night. The rear end is the 10 bolt but with a torsen differential and motive 3.73 gears. I don't even have the girdle on it. I pull consistent mid 1.6 60fts and I have about 10k miles on the setup. The motor/tranny now have 43k miles on them and the car has 100k on it. Tranny just started to slip on me though, but a new one will fix that problem. I'll be shooting for 11.2x on motor with a few other mods and good weather.
Old 07-06-2004, 03:56 PM
what RR and push rods did you get?
are you still on the stock fuel pump with the 30# Inj.
Old 07-06-2004, 04:21 PM
Somnambulist's Avatar
the cams offered in the LE packages ARE Joe O cams. he just had a Joe O cam from when Joe used to do custom grinds for the general public. now Joe just grinds cams for Lloyd and one other guy...
Somnambulist is offline
Old 07-06-2004, 05:08 PM
I'm running the comp magnums(not the pro mags cuz i'm cheap) and the cmotorsports $36 pushrods. I'm running a holley fuel pump only because my stocker died awhile back. With the 30lb injectors I hit max of 83% cycle duty. Also my shift points are set at 6450. Anything else let me know.
Old 07-06-2004, 06:06 PM
TQdrivenws6's Avatar
I assume you have the 30 lb SVOs?
When you saw 83% duty cycle, what was your fuel pressure?
I have the LE2 heads with the LE1 cam(slightly bigger than yours) that are getting installed in a few days here, and I am planning on running the stock fuel pump with an aftermarket regulator and some SVO 30 pounders to start out.
If you have a copy of the original dyno sheet (although you have more power now) I would be very interested to see it, so if you could email it to me it would be very much appreciated.
Thanks,
Chris Bailey
TQdrivenws6 is offline
Old 07-06-2004, 06:21 PM
Thanks,
Chris Bailey
Yes I have the SVO's, and I'm running a stock fuel pressure regulator right now. I'd have to dig up the dyno sheet, its around here somewhere.
Old 07-06-2004, 06:25 PM
If you could get that to me that would be awesome. I will be getting a dyno tune in 1.5-2 weeks, and will definitely get the sheet hosted when all is said and done.
Chris
Old 07-06-2004, 06:41 PM
Sounds good. I'll probably be dyno'ing again in about a month. I'll post that sheet for you also.
Old 07-07-2004, 08:04 AM
will a stock fuel pump work with the 30# SVO's?
Also my headgaskets are blown so this is why i am kinda in a hurry to get the heads and cam done.
If i just have the stock stall with the LE1 heads and cam how will the car drive.
So this is a break down of what i will need.
LE1 heads and CAm
RR and Push Rods (stock size push rods?)
30# Inj
Head, WP, Timeing cover, gaskets (can i get all the gaskets in a set?)
New timing set (what is the cheapest way to handle this)
Mail Order Tune
8515181 Beers
Anything i am forgetting?
LeftoverChinese
01-14-2024 03:03 PM
F'n1996Z28SS
08-23-2023 11:19 PM
Queens94z28
12-20-2014 09:11 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: Do u have the LE1head and cam package? what do you run?
