do they make a "spark plugs wrench"?
Re: do they make a "spark plugs wrench"?
holy crap! I just looked at the price of this SLP shortened spark plug socket... 21.95 + 8.95 handling= ~$31... Is this the only company that makes a shortened spark plug socket? I take it that this wouldn't be something i'd find at Sears would I?
Just take a standard spark splug socket and grind it down. Same difference.
Or you could buy this, once again same difference.
http://cgi.ebay.com/ebaymotors/LT1-L...spagenameZWDVW
U may have to drill out teh center a little but do that and grind it down
Guest
Posts: n/a
Originally Posted by cb94ta
slp makes a plug socket, it's a short socket I know they sell it in summit
Originally Posted by 93camaroLT1
I take it you just grind the sides of the socket down after cuting it in half and drilling the center out, so that you can grip the socket with a wrench?
I have Jet Hots and I find that changing those from the bottom are EASY. It's simple getting a wrench in there, just wedge your arm in there and you'll be fine. My arm fits.
Agreed! Especially that dam passanger side.
Just make sure you unplug the battery first. I had a nice little light show once, when my wrench hit the starter. WOWZA!
Mike
Mike
Mike
Mike
Haha, that's happened to me quite a few times, and it was nuts!
Guest
Posts: n/a
Are you guys using a offset 5/8" wrench OR a will a normal boxed 5/8" wrench to get the plugs on the passenger side from underneath the car? Just wondering cuz the normal 5/8" wrench doesnt work from the top, I was trying to pick up a offset one today but no where but sears carried one and sears was out of stock on them.
YES! and double, tripple, and then once again check that no plug wires are close to those dam primarys. I went ahead and purchased them Taylor heat sleeves. Those suckers are worth each little penny I spent. I have had them making direct contact with the headers, and there is not even a burn mark on them.
Mike
Mike
94z28jbw
Sep 8, 2002 03:22 PM
