Do they make plastic MAF ends for LT1 cars???
Old Sep 8, 2004 | 05:57 PM
JD30thZ28's Avatar
I was curious whether anyone knew of any companys that offer Plastic MAF ends for the LT1 MAF, I know they have them for the LS1 guys but would they work with the LT1 MAF??? Thanks
Old Sep 8, 2004 | 06:12 PM
Z-RATED94's Avatar
Re: Do they make plastic MAF ends for LT1 cars???
I have a set, some kind of composite material, inside opening is larger than stock, not sure where I got them from or if the company still makes them. I could let you have mine for $60 shipped if your interested, but you would have to wait at least a month. Going in for surgery on Mon. and not sure how long before I'm up and about. Maybe someone else can help you out.
Old Sep 8, 2004 | 06:31 PM
944v8inDFW's Avatar
Granatelli Motor Sports makes plastic ends. Usually in the $80 range. My only warning there after using a set is my may have to mod your center section just a bit for proper fit, and the 2 sets i have bought have had a pretty rough finish in spots on the inside. I bought them only for track use: 2 reasons 1) lighter weight 2) avoid heat soak
Old Sep 8, 2004 | 06:35 PM
JD30thZ28's Avatar
Yeah i just wanted to change them to avoid heat soak. Thanks for the help guys. Z-rated I may take you up on that offer, i will e-mail you soon. Thanks
Old Sep 8, 2004 | 06:37 PM
96capricemgr's Avatar
Unless you know what you are doing leave the MAF stock, otherwise all you will accomplish is screwing up a precision measuring device.
Old Sep 8, 2004 | 06:38 PM
944v8inDFW's Avatar
ps
be advised you may need a tune on your computer after install as the air flow changes way up. Like porting the MAF. Just my expierence.
Old Sep 8, 2004 | 06:57 PM
944v8inDFW's Avatar
yeah what he said
TYLER94Z28
Dec 3, 2014 07:05 AM
USAirman93
Nov 24, 2014 03:37 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
Jul 4, 2005 05:00 PM
Geeterman
Aug 4, 2002 04:03 AM
