Do they make plastic MAF ends for LT1 cars???
I was curious whether anyone knew of any companys that offer Plastic MAF ends for the LT1 MAF, I know they have them for the LS1 guys but would they work with the LT1 MAF??? Thanks
Re: Do they make plastic MAF ends for LT1 cars???
I have a set, some kind of composite material, inside opening is larger than stock, not sure where I got them from or if the company still makes them. I could let you have mine for $60 shipped if your interested, but you would have to wait at least a month. Going in for surgery on Mon. and not sure how long before I'm up and about. Maybe someone else can help you out.
Granatelli Motor Sports makes plastic ends. Usually in the $80 range. My only warning there after using a set is my may have to mod your center section just a bit for proper fit, and the 2 sets i have bought have had a pretty rough finish in spots on the inside. I bought them only for track use: 2 reasons 1) lighter weight 2) avoid heat soak
Yeah i just wanted to change them to avoid heat soak. Thanks for the help guys. Z-rated I may take you up on that offer, i will e-mail you soon. Thanks
Originally Posted by 96capricemgr
Unless you know what you are doing leave the MAF stock, otherwise all you will accomplish is screwing up a precision measuring device.
Jul 4, 2005 05:00 PM
Geeterman
Aug 4, 2002 04:03 AM
