View Poll Results: Do they look correctly aligned?
Yes - Find something fun to do this weekend
25.00%
No - Spend the entire weekend disassembling car
75.00%
Voters: 4. You may not vote on this poll
Do these cam timing marks look aligned to you?
Old Aug 25, 2004 | 10:31 PM
davepl's Avatar
When I built my 396, I degree'd the cam in but then had to r&r the timing chain, and I've been wondering every since how careful I was aligning the cam and crank gears. By luck I happened to have this photo around, but the crank's been rotated a bit.
If you go back three teeth on the crank gear and ahead three on the cam gear, care to make a guess from this photo as to whether they're aligned? Sadly the teeth aren't lined up in this photo, so you have to guess whether the teeth are about to meet (good) or just passed each other (bad). It ain't scientific, I know, but its a lot more fun than pulling the blower, balance, water pump, optispark, etc to double check!
http://www.memturbo.com/Engine.JPG
Thanks,
Dave
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
ChrisFrez
Dec 7, 2014 11:32 AM
Noenav
Dec 6, 2014 07:35 PM
