Do the LT1's hold 5 quarts of oil?
Old Jun 3, 2003 | 03:30 PM
Ace_437's Avatar
I need to change my oil and cant remember the exact amount to use. Somebody clue me in.
Old Jun 3, 2003 | 03:32 PM
Slappy3243's Avatar
I just pour oil in until it starts overflowing out of the fill tunnel.
-Adam
Old Jun 3, 2003 | 03:33 PM
Ace_437's Avatar
Great! I'll do that then.
Old Jun 3, 2003 | 03:40 PM
1fast95Z's Avatar
If you use a PF1218 filter, it takes 5 quarts exactly.
Old Jun 3, 2003 | 03:45 PM
Mindgame's Avatar
Fill the filter and moisten the seal before installing it. Then add 4 quarts. Allow time for drain-down. Then check the oil level... add oil as necessary.
-Mindgame
Old Jun 3, 2003 | 04:19 PM
Even the owner's manuals vary from 4.5-5 quarts from 93-97 and they all used the same filter.
I've always done 5 with the old standard PF25 and have had no troubles.
Old Jun 3, 2003 | 06:15 PM
Fastbird93's Avatar
My 93 service manual says 4.5 -- 94+ used 4 quarts.
Old Jun 3, 2003 | 06:43 PM
That's not totally accurate (but what is? )
Here is what the owner's manuals actually say and it is not going to help the confusion any:
1993
Camaro/Firebird 4.5
1994
Camaro/Firebird 5.0
1995
Camaro 4.5, Firebird 5.0
1996
1997
Camaro/Firebird 5.0
This is with filter change if the manual mentions it.
Just fill it to the full mark on your particular dipstick.
Old Jun 3, 2003 | 08:30 PM
Fastbird93's Avatar
WHOOPS! I meant to say that 94+ used 5.0.
Old Jun 3, 2003 | 10:48 PM
96LT14u2Nv's Avatar
mine usually takes 4.5 but i always buy 5 quarts just in case. i usually pour in 4 1/4 and then start for a few minutes and add more as needed. but 5 just in case
Old Jun 4, 2003 | 04:05 AM
Patman's Avatar
I run the long filter and put in 5.3 quarts. In the past I've even run 5.5 with no problems.
Old Jun 4, 2003 | 07:35 AM
anasazi's Avatar
hmm i put in 5.5 last time i did mine... no problems so far, what should i be looking for?
Old Jun 4, 2003 | 07:38 AM
FastZinTennessee's Avatar
Weird, using the PF25 filter(or equivalent) I have always used 5 quarts. It comes up exactly to the full line too.
John
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
