Do I need a stronger starter?
Old May 23, 2007 | 11:07 PM
Jazsun's Avatar
All I have is said mods in my sig, recently my starter cracked in half (between the two cylinders) and a bolt severed in half. I am trying to find a replacment should I stick with another Lt1 starter or is it like "once you break one your gona break em all" so should I get a stronger Lt4 or mini high torque starter.
I don't want to spend more then $90
Old May 23, 2007 | 11:30 PM
SS RRR's Avatar
Are you sure one of those bolts (especially the one that was broke) was torqued properly? Ultimately no you don't need a stronger starter w/ what you have done.
It's also possible through time the starter casing developed stress cracks and finally gave out. Dunno...
Old May 24, 2007 | 06:10 AM
SS RRR's Avatar
Originally Posted by camaroRI
my car started going through starters like once a year from the headers, i just replaced it with one of the generic small block chevy starters for 30 bucks at the parts store, when it breaks just replace it for 30 bucks ....
Just order a starter for a 81 camaro 350 or something, it will be like 30 bucks or something stupiid, as opposed to the hundred plus for a lt1 starter that wont last for ****.
Didn't you have to shim it? Does it mesh on your flywheel correctly?
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
karpetcm
Aug 14, 2015 03:02 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
