Do I need to pull hub to remove vented opti?
Old Jun 12, 2005 | 04:39 PM
RichJ's Avatar
Do you need to pull the crank hub to remove a VENTED (95+) opti? I've seen posts that say that the hub can stay on, but it seems like the vent tube is in the way of it clearing the hub. I haven't struggled with it too much yet. Just wanted to check and see if the hub needs to come off before I get too frustrated. I'd prefer not to remove the hub if I don't have to for obvious reasons.
Thanks!
Old Jun 12, 2005 | 04:46 PM
30696bird's Avatar
Re: Do I need to pull hub to remove vented opti?
you have to remove the round part (Damper), but not the hub itself. Just line it up with two "ears" on top and the opti will come right out.
Old Jun 12, 2005 | 04:56 PM
RichJ's Avatar
Hmm...my "ears" are on top and the lower vent tube is hitting one of the ears, but it looks like it might clear if I turn the hub a little hit to the right. I guess I should struggle with it a bit longer. So, you are talking about a vented opti, right? It looks like it would be easier with a non-vented opti. Thanks.
Old Jun 12, 2005 | 05:27 PM
chuckd4more's Avatar
I've had my opti off a couple of times and don't remember having to remove the hub. I know I didn't now that I think of it.
Old Jun 12, 2005 | 06:34 PM
Canuck wita WS6's Avatar
No need to remove the hub. Use this opti guide to see where to position the hub for easy opti removal. http://www.streetillusionsracing.com.../opti/opti.htm
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
