Do I need o2 extensions for both sides?
Old Aug 11, 2005 | 03:40 PM
Inutero's Avatar
I have a 95z with pacesetter LT's. Do I need o2 extensions for both headers?
Old Aug 11, 2005 | 03:45 PM
madwolf's Avatar
Re: Do I need o2 extensions for both sides?
Only one on the passenger side will do.
Old Aug 11, 2005 | 03:55 PM
BlackScreaminMachine's Avatar
maybe in stock form that will do, i mean untouched wiring harness. But mine has been disconnected and moved so many times. With my Jet hot LT's I did both sides, 24" was a little too much so if you can find 12" that would be ideal. I may have a unique situation but not many cars are left "untouched"
Old Aug 11, 2005 | 03:59 PM
The Engineer's Avatar
The 1996 & 97 LT1s have dual front and rear O2 sensors (in front of the Cats and behind) and requires front extensions on both sides. I'm not sure about your year model as the exhaust is different? Also, if you eliminate the Cat/s, you'll need rear O2 simulator/s, or PCM programming to turn-off that function.
Old Aug 11, 2005 | 04:01 PM
madwolf's Avatar
He has a 95. (signature and post)
Old Aug 12, 2005 | 03:52 AM
Inutero's Avatar
So I need one 12" extension on the passenger side? thanks guys.
Old Aug 12, 2005 | 10:07 AM
speedcrazy's Avatar
i bought 2 24" extensions for mine and i needed both so im not sure why you would only need one? u dont necessarily need 24" but i think u need 2 extensions at least.
Old Aug 12, 2005 | 11:18 AM
EKO's Avatar
EKO
My 94 needed two...
Old Aug 12, 2005 | 12:03 PM
madwolf's Avatar
93-95 cars SHOULD NOT need a driver side extension unless the harness has been moved around and it is not routed correctly.
Old Aug 12, 2005 | 02:55 PM
Inutero's Avatar
Does this also depend on what o2 sensors we you guys may have bought? I know some o2's wires are longer than others.... I bought Bosch a couple of months ago and they went bad after a week. What should I go with this time?
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
May 22, 2015 08:28 PM
grabbem88
Apr 16, 2015 06:57 PM
bee20e
Parts Wanted
Nov 27, 2014 05:20 PM
Jul 4, 2005 05:00 PM
