Do I need a new oil pan for a 396 strkr
Old Oct 22, 2003 | 11:17 PM
sharp28's Avatar
I'm getting a 396 short block from combination. I talked to Sam already about it and he said I didn't the canton pan, that i could get away with using my stock pan with just a little clearancing.
Has anybody used their stock pan?
Thanks Aaron
Old Oct 22, 2003 | 11:28 PM
atljar's Avatar
Big hammer and knock it out from the inside. You will have to clearance the canton pan too.
Old Oct 22, 2003 | 11:32 PM
missetti's Avatar
I'm in the process of finishing a 383 stroker, and I was able to use my stock pan. Didn't even have too beat on it.
Old Oct 23, 2003 | 12:10 AM
sharp28's Avatar
Thank you both. The canton is just too expensive. By the way, what type of oil are you using.
Old Oct 23, 2003 | 12:15 AM
atljar's Avatar
Have you turned the motor over with the pan bolted bolted down???
Oil, break in just use some cheapo oil. 10w-30. Dont use synthetic on break in. After you have changed the oil a bunch of times within the first 200 miles, you can go synthetic.
Old Oct 23, 2003 | 01:21 AM
carlos64030's Avatar
I'm using the stock oil-pan that was massaged by my engine builder. Check out the pictures in my sig.
Old Oct 25, 2003 | 11:09 AM
Lt1tko5o's Avatar
Just built a 383 for my friend, no modifications needed for the oil pan, guess I'll find out for my 396 when it goes together.
Brian
HectorM52
Jul 30, 2017 11:46 AM
jl1ne
Jul 7, 2015 08:38 PM
SergheiS
Jul 5, 2015 03:27 AM
SergheiS
Apr 26, 2015 08:15 PM
