Do I need a Knock Module for my engine?
Old Dec 27, 2004 | 10:57 PM
bbuice's Avatar
I am building a 383 with forged pistons and roller rockers do i need a aftermarket Knock Module for my set up?My car is a 1993 TA if I need one where is it located on the car?does a 1993 have one?Thanks!
Old Dec 27, 2004 | 11:00 PM
1racerdude's Avatar
Re: Do I need a Knock Module for my engine?
If you have headers you need an in line resistor or have the KM tuned out of your computer. You can spend the money on a LT-4KM but it won't work.
Old Dec 27, 2004 | 11:01 PM
A 1993 does not have a replaceable knock module.
Old Dec 27, 2004 | 11:08 PM
bbuice's Avatar
So what do I do if it,s not replaceable?
1racerdude's Avatar
OPPPPsssss it is speed density.Didn't read it well enough.
Old Dec 27, 2004 | 11:58 PM
You don't need to do anything, unless there is a problem with it. If you are a victim of false knock, you can try desensitizing the circuit (a search should get you some info). Like anyone else, you would use a scan tool or data logging software to give you some data on the knock counts.
Old Dec 28, 2004 | 08:50 AM
ejfagala's Avatar
Make sure you TQ your knock sensor to the proper TQ spec (14 Ft Lbs) and run scan master, my guess is you will be fine. If you do see knock you need to make sure it is false before doing anything. If you do end up with "False knock" there are several trick to "Desensitze" the sensor including teflon tape and a 90 deg elbow. The best thing to do is run it and see where you are at. Just remember that witout the sensor you are one bad tank of gas from starting over.
MadMav
May 25, 2015 09:35 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
SC97TA
Sep 15, 2002 01:10 AM
