Do I need a Knock Module for my engine?
I am building a 383 with forged pistons and roller rockers do i need a aftermarket Knock Module for my set up?My car is a 1993 TA if I need one where is it located on the car?does a 1993 have one?Thanks!
Re: Do I need a Knock Module for my engine?
Originally Posted by bbuice
So what do I do if it,s not replaceable?
Make sure you TQ your knock sensor to the proper TQ spec (14 Ft Lbs) and run scan master, my guess is you will be fine. If you do see knock you need to make sure it is false before doing anything. If you do end up with "False knock" there are several trick to "Desensitze" the sensor including teflon tape and a 90 deg elbow. The best thing to do is run it and see where you are at. Just remember that witout the sensor you are one bad tank of gas from starting over.
Jul 4, 2005 05:00 PM
