Do I need to get my shift points reprogrammed with a higher stall?
Old Feb 20, 2004 | 10:41 PM
slider's Avatar
I'm putting a 3500 stall in shortly. Should I have my shift points reprogrammed? If so, what should they be changed to?
Motor is stock. Car just has bolt ons.
Old Feb 21, 2004 | 05:40 PM
Josh-'04 GTO's Avatar
I think shift firmness will be more of an issue. It's pretty common for stall convertors to soften up the shifts, so a shift kit or even bumping the line pressure through the PCM is a good idea. Altering shift points won't help much on a predominantly stock car.
Old Feb 22, 2004 | 03:54 PM
96capricemgr's Avatar
My car surged pretty bad when I lifted off the throttle and coasted, and mine is only a 2800stall, reprogramming fixed it, the shift firmness is a good point as well.
Old Feb 22, 2004 | 04:08 PM
97Z-M6's Avatar
yep you will need some work there. you will probably have to work in the normal shift and the kick down shift tables.
down you have tuner cat? will you be doing the programming. or are you having it done
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
