do I need to drain coolant to remove intake/valvetrain?
Old Apr 15, 2006 | 08:17 AM
Hawk's Avatar
I'm going to take off the valve covers and possibly the intake manifold. I want to inspect my valvetrain for damage. My question is, when I do this do I need to drain the coolant first?? I wouldn't think so but I know the LT1 is reverse flow cooling and maybe there is some wierd reason I might have to.
THanks,
Brian
Old Apr 15, 2006 | 08:45 AM
aboatguy's Avatar
Re: do I need to drain coolant to remove intake/valvetrain?
You do not have to touch the cooling system to pull the valve covers and
there are no coolant passages in the intake. If your car is stock you will have coolant in the throttle body. I lower my coolant level until it now longer comes out of the tubing that connects the heads to the TB.
Mike
Old Apr 15, 2006 | 09:21 AM
Javier97Z28's Avatar
Moderator
Mike
^^^ correct ^^^
Old Apr 15, 2006 | 09:29 AM
Hawk's Avatar
awesome.
Time to start turning some wrenches.
Old Apr 15, 2006 | 09:32 AM
Moderator
Originally Posted by Hawk
awesome.
You have 30 minutes to complete this task.. GO GO GO
Old Apr 15, 2006 | 10:29 AM
aboatguy's Avatar
30 minutes!
Old Apr 15, 2006 | 10:50 AM
BlackScreaminMachine's Avatar
I could do it in 30 minutes....
My whole intake from elbow to CAI filter is one peice, so 1 elbow to TB clamp, 2 sensor wires, 1 AIR tube and bam its out. 2 minutes
Then its wiring harness, 5 minutes
Throttle and cruise cable 3 minutes (with bracket)
Fuel lines 5 minutes as long as you know how to use the tool
10 Minutes for the intake manifold bolts
If you need to mess with the egr tube in back give it another 10 there just in case, 30-40. No sweat
Old Apr 15, 2006 | 12:31 PM
Moderator
30 minutes!
Yep, that's how long it took me last time I pulled my intake
Takes me a little longer on stock cars that still have all the factory clips and crap, the injector clips (i've got svo's), etc...
blac94Z
Feb 15, 2021 09:43 PM
warmeck
Apr 16, 2015 05:53 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
