Do I need to change the oil pump
Old Jul 13, 2015 | 10:28 AM
big_mac421's Avatar
Exclamation Do I need to change the oil pump
Hi I'm new to this site and I have a 1994 Chevy Camaro z28 with about 168,000 miles on it. When the car is at an idle the oil pressure is fine but when I give it gas the oil pressure drops, does the oil pump need to be changed?
Old Jul 13, 2015 | 10:44 AM
Re: Do I need to change the oil pump
Can you give some numbers (idle, cruising, what RPM)? Chances are it is from bearing wear and not the oil pump.
Old Jul 13, 2015 | 03:48 PM
Chimera96's Avatar
oil pump itself rarely fails. The oil pump drive gear has been know to strip. Typically because the top part that is bolted to the block (plastic) breaks/cracks raising the drive gear off the cam and it strips. You would likely see quite a bit of metal shavings I oil though
bearing wear is the most typical reason for low/none oil pressure...
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Aug 8, 2002 02:53 PM
