Do I need a bigger TB?
Old Mar 1, 2005 | 06:36 AM
Ramairgod69's Avatar
Throttle body
88 GTA fiberglass ram air hood and wing, centerline rims, 3.70 gear, 700R4, trans go kit, B&M megashifter, vigilante 3800 stall, LT1 w/ 195cc AFR heads, airfoil, K&N, comp cams 1.6 roller lifters, extreme energy comp cam 224/230, underdrive pulleys, msd plus 6, high voltage coil, 30 lb injectors, american thunder exhaust, TB bypass, 160 degree thermostat, custom burn ecm, T6 aluminum LCAs, Subframe connectors, Hooker super comp LT, muffelex Y
Coming soon: MT ET street slicks
With this combo is my TB a limiting agent for air flow?
Old Mar 1, 2005 | 07:59 AM
1-bad-z28's Avatar
Re: Throttle body
I would say so. I saw a post a couple of weeks ago on tb's and it was saying there is no adverse effect of going to a 58mm as opposed to a 52mm. If you do more mods in the future you will need the 58mm anyways so you might as well get it now.
Old Mar 1, 2005 | 08:55 AM
RE AND CHERYL's Avatar
Re: Throttle body
A 52mm throttle body will flow about 750 CFM. That is more than enough for your mods.
There's a guy on this board that was running 11.70s with a LE setup and a stock TB. Switching to a 58mm TB netted him about 5 hundreths.
Old Mar 3, 2005 | 06:16 AM
Do I need a bigger TB for my application? I am currently running a stock TB.
My combo is in my sig.
Old Mar 3, 2005 | 06:20 AM
1-bad-z28's Avatar
Re: Do I need a bigger TB?
didn't you post this exact same question a couple of days ago?
Old Mar 3, 2005 | 10:24 AM
This is a duplicate of your earlier post:
http://web.camaross.com/forums/showt...89#post2875189
As a suggestion, do not repost the same question. If it has slipped off the bottom of the screen, and you want to bring it back up to the top, it is acceptable to do a "TTT" post to bring it back. Just wait at least 24 hours from the last response before you "TTT".
I am merging the two threads.
magman
Apr 15, 2016 03:08 AM
Hal Fisher
Sep 30, 2015 09:03 PM
95craz28
11
Sep 12, 2015 07:47 AM
nd4spd200
Aug 21, 2015 09:30 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
