Do I install the rear main seal dry?
Old Dec 30, 2004 | 09:43 PM
speed_demon24's Avatar
So far 2 people told me to put a light coat of black RTV on the outside and a light coat of oil on the inside, and one guy told me to install it dry. Which is it? Its a GM gasket if that matters.
Old Dec 30, 2004 | 09:57 PM
Re: Do I install the rear main seal dry?
My new GM seal had some lubricant applied to the inside. I used no sealant on the outside.
Old Dec 30, 2004 | 10:11 PM
stew's94z's Avatar
I would install the outside dry.
Dean
Would some RTV on the outside of it hurt anything at all? It looked like it was leaking out the outside of it a bit...
Old Dec 30, 2004 | 10:19 PM
stew's94z's Avatar
If all parts are clean and the seal is installed correctly it needs no sealant.
If the seal is cocked or was beaten in by a big hammer enough to egg shape the od of the seal it could leak on the outside.
Dean
Old Dec 30, 2004 | 10:41 PM
Um I don't know which way it goes in. On the outside it narrows up a bit, and I'm guessing the narrow part is the front? And I really dont see any lube in the middle.
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
redleader
Jan 22, 2015 12:05 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
