Do I have to use the spacer that came with the crank hub bolt???
Old Nov 10, 2003 | 11:58 AM
96 WS6's Avatar
I'm sorry this is the last crank hub thread as I'm just as sick of it as you guys are. I just wanted to know if there is anything special about that washer/spacer.
Old Nov 10, 2003 | 12:14 PM
bradpreece95z28's Avatar
I used mine. I have to ask the question. why wouldnt you wanna use it man?
not tyting to be a peckerhead..just wondering.
Old Nov 10, 2003 | 12:18 PM
BradZ28's Avatar
I'm pretty sure it will bottom out without it....also it functions as a washer to "lock" the bolt in place. If you lost it or something I would either buy a new one or cut the bolt down some.
Brad
Old Nov 10, 2003 | 12:24 PM
96 WS6's Avatar
Im actually no longer using a stock sized bolt. I went through a bunch of drama and ended up helicoiling the hub bolt hole and installing new threads. So in turn the bolt I'm using is 1/2 inch shorter than the stocker. It will fit like that but it would grab more thread if I used a thinner washer. I could cut it down I suppose... I'd like to use that spacer too I was just wondering if anybody did the !spacer mod . If I cut the bolt down there is a chance it won't catch when I try to thread it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
