What should I do?
Old Nov 9, 2003 | 02:27 PM
aintno6's Avatar
What should I do?
Ok I allready bought a set of used lt1 heads with low miles that have the lt4 springs etc.. These are alose the 52cc heads. And I also purchased a lt4 hot cam at the same time too. I was planning on getting the heads lightly/street ported and throwing on some bolt-on's as well.
I know the hot cam is a great cam, and it kicks a$$. But Im not sure if I should pick a different cam.
Would it be better to throw in the hotcam with the street porting on the heads, or not spend the money heads and go with a cc306 and get a good valve job? I would have an extra set of heads eitherway I go for future use. Which would most likely make more power?
Old Nov 9, 2003 | 02:32 PM
Spinner's Avatar
Pfft, go big if your gonna go at all. 847
Old Nov 9, 2003 | 08:59 PM
aintno6's Avatar
are you serious about the 847?
An other question. The car has 75k on it. Should I change the opti with the cam swap. Or wait till it goes? Its 97 Formy dunno if the vented opti's last longer?
Old Nov 9, 2003 | 09:10 PM
Spinner's Avatar
Dead serious
97' formulas already have vented optis, but if you have the cash, it cant hurt.
Old Nov 9, 2003 | 09:55 PM
aintno6's Avatar
Ok so what do you guys think. cc306 or GM847, no porting just a valve job?
What springs and seats should I go with? Any part #'s? Because I doubt the hot cam springs will work.
Old Nov 9, 2003 | 10:23 PM
95TA8280's Avatar
From what I hear, people with the hotcam wish they went higher after awhile. When I had my 95, I wish I did after a few months. I wanted a loopier idle......
Old Nov 9, 2003 | 11:19 PM
aintno6's Avatar
so anyone know what springs I would need? Or if I would have to get new valve seats?
Old Nov 9, 2003 | 11:28 PM
Spinner's Avatar
For a big cam, you should replace everything in your valvetrain. Lifters too if they're looking worn
Old Nov 10, 2003 | 01:15 AM
aintno6's Avatar
I do plan on changing the whole valve train. But I need to know what springs to use for a cam like the cc306 or gm847?
Also what valve seats do I need?
Anyone??????????
Old Nov 10, 2003 | 12:25 PM
aintno6's Avatar
Can any of you cc306 guys help me out here? Or should I call comp cams and see what they recommend for springs and valve seats?
