Do I have to port manifold right away for 58 tb?
Old May 30, 2005 | 10:26 PM
80TA's Avatar
I plan on porting my intake manifold when I do heads/cam and headers next year but was wondering can I bolt on a 58 tb right now or will the blades not open properly with the 52 size hole stock in the intake?
Old May 30, 2005 | 10:39 PM
CMANZ28's Avatar
Re: Do I have to port manifold right away for 58 tb?
Yea you need to port the opening....or get a spacer. I remember seeing a spacer so you dont need to port your manifold, but do it right...PORT IT!!!!
Old May 30, 2005 | 10:50 PM
96vortechSS's Avatar
You need to port the manifold so the ariflow won't be restricted. I don't think it'll hit the maniflods 52mm openings. I need to port my manifold also. I installed a 58mm tb a little over two years ago without porting and I haven't had any problem to support the throttle blades striking the manifold at WOT. It doesn't dyno as much N/A though as when I had the 52mm on the car though.
Old May 31, 2005 | 12:18 AM
SStrokerAce's Avatar
Why not port it? Yank it off and do it the right way.
Bret
bunker
Aug 31, 2015 01:46 PM
whitehooptie
Aug 17, 2015 08:35 AM
bunker
Aug 1, 2015 09:47 PM
alphaauto
Jul 26, 2015 04:40 PM
13qtr
Jul 19, 2015 05:30 PM
