Do I absolutely need a 4 bolt block...
Old Nov 26, 2006 | 07:06 PM
wrd1972's Avatar
Here are the specs:
355 CID decked block
Mahle forged flat pistons (around 11.2 CR)
LE2 heads
Impala head gasket
LE 1.5 cam
ported intake
1.6 RR's
RK-sport headers
52mm
all bolt ons except e-water pump
rest in signiture.
Plan on spinning to 6500 RPM max.
Really trying to decide if I need to persue a 4 bolt block or just get ARP studs for my 2 bolt block. I understand that that the 4 bolt is never a waste, but if its overkill for my application I will pass. BTW I am hoping for around 400 HP to the wheels and I will never have any power adders.
Old Nov 26, 2006 | 07:44 PM
Javier97Z28's Avatar
Moderator
If that's *all* you plan to do.. I'd say overkill.
But if you can get one cheap enough to start with, why not?
Old Nov 26, 2006 | 07:51 PM
godspeed1976's Avatar
I would say 4 bolt mains are not neccesary, but if you have it stripped down they would make for added insurance. It also will allow you "room to grow" should you get the bug for even more power in a few years. Just my .02 cents
On another note: Your dyno numbers seem low to me. Especially for having a LT4 cam and 1.6 rr's and the fact you are a M6.
Old Nov 26, 2006 | 07:59 PM
wrd1972's Avatar
Dyno numbers are on bone stock LT1 camshaft.
Old Nov 26, 2006 | 08:26 PM
Sweet I was worried about that.
Old Nov 27, 2006 | 05:57 PM
wrd1972's Avatar
I have some ARP main bolts, are the studs still stronger and the better way to go?
Old Nov 27, 2006 | 07:47 PM
SS RRR's Avatar
If you plan on spraying then definately get billet caps. Either two or four bolt. Just know it's a little spensive...
Old Nov 27, 2006 | 07:55 PM
wrd1972's Avatar
I will never have the spray or any other power adder.
Old Nov 27, 2006 | 08:01 PM
reamo04's Avatar
^i thought that too until i rode in a nitrous powered car....and then a procharged car...and then one with both
now i am going to build a procharged 396 w/ dual stage nitrous
Old Nov 27, 2006 | 08:14 PM
wrd1972's Avatar
Well here is the way I see it. NOS is out of the question.
If a blower with X amount of boost can co-exist with 11.2 compression ratio then I might go that route. I see that as being very unlikely.
Old Nov 27, 2006 | 08:46 PM
93formula's Avatar
the two bolt mains can handle up to 650 hp. so if you only want to make 400hp your fine.
Old Nov 28, 2006 | 02:12 PM
SStrokerAce's Avatar
For what you are doing.... 2 bolt mains wiht a stud kit will work ok. Just make sure their is enough bearing clearance, you use good oil and the balance is very good and you shouldn't have problems. A 4 bolt is always better though.
Bret
Old Nov 28, 2006 | 03:20 PM
wrd1972's Avatar
Bret
Stupid question.
What exactly is bearing clearance in detail please?
Old Nov 28, 2006 | 03:35 PM
do a search on it.... bascially bearing clearance is the area between the crank and bearings. Its going to be in the .002-.004" range.
Bret
Victor Lamb
Aug 26, 2017 02:52 PM
Heathen1
Jan 2, 2016 04:27 PM
timmy39120
May 2, 2015 05:12 PM
maybe2fast
Mar 16, 2015 09:45 AM
