Do all duals rattle?
Old Nov 6, 2004 | 04:25 PM
Cmr0z28's Avatar
Do all true dual systems rattle? I heard they all do since the exhaust is mounted to the body, regardless of how quiet the system is. Is it true?
Old Nov 6, 2004 | 04:59 PM
02transam 513's Avatar
Re: Do all duals rattle?
Wouldnt think that would be true, but would like to know also.
Old Nov 6, 2004 | 05:59 PM
tonylittell's Avatar
mine doesnt.....i would think only a poorly designed exhaust would rattle ...weither its true dual or not
Old Nov 6, 2004 | 06:03 PM
97FormulaWS-6's Avatar
Mine doesn't rattle or drone at all...
Old Nov 6, 2004 | 06:52 PM
Cmr0z28's Avatar
Full specs please?
Old Nov 6, 2004 | 06:57 PM
Cmr0z28's Avatar
Nevermind, looked on your cardomain page.
Old Nov 6, 2004 | 07:20 PM
Camaro_Maniac63's Avatar
Mine doesn't rattle either. It does, however, make loose objects in the car rattle
Old Nov 6, 2004 | 07:21 PM
Loadre's Avatar
Just tighten it down with a piece of rubber in between the exhaust and the body and it does wonders.
Old Nov 6, 2004 | 07:54 PM
ford's Avatar
Umm i dont have any issues with it rattling. If you do it correctly and spend the money to have it done right, you won't have a problem at all. BTW i run 3" all the way from front to back.
Old Nov 7, 2004 | 06:11 PM
mine is 3 inch from the headers back as well...
Old Nov 7, 2004 | 08:20 PM
90 Z28SS's Avatar
ditto , I never had a problem with mine rattling . I did use rubber isolated mounts and made sure I had enuff clearence to allow a "little" movement .
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
autoxr166
Sep 25, 2015 04:21 PM
