DMH cutout doesn't work
Old Jul 8, 2006 | 06:22 PM
Cmr0z28's Avatar
Angry DMH cutout doesn't work
So I got my dual 2.5" E-cutouts today...and made the mistake of not testing them before installation. I welded the cutouts in right after the headers, ran the wiring and whatnot, then I ran into a problem. The studs on the included cutouts aren't long enough to bolt the cutouts on with gaskets. Next problem...1 of the cutouts doesn't work, the motor just makes an "e-er" sound and doesn't move. I switched the wiring and still no luck...tried calling DMH and got no answer.
Has this happened to anyone else? I'm sure Dave will replace it assuming I can get a hold of him.
Old Jul 8, 2006 | 07:13 PM
LT1_383's Avatar
Re: DMH cutout doesn't work
I had the same problem with my Mccord cut out, the flange was too thick to use the stock studs on the cut out pipe. Before i installed the cut out i ground down the welds on the studs for the cut out. Cleaned the holes up and used a wire wheel to get the paint off the surrounding area. Then bought new bolts, put a nut on the other side to keep them straight and tack welded them in place.
Old Jul 9, 2006 | 07:56 AM
Dave Hacker's Avatar
Hey Matt, I will be in the shop Sunday until around 2pm. Give me a call if you get a chance.
Old Jul 9, 2006 | 10:37 AM
Cmr0z28's Avatar
Talk about customer service . DMH =
Old Jul 9, 2006 | 12:40 PM
Makaveli's Avatar
hey dave, i sent you a few PMs and i can never reach through on the phone. let me know if you got my pm's
Old Jul 9, 2006 | 02:18 PM
Cmr0z28's Avatar
Works now...
http://www.mattz28.com/Z28/Z28Ecutouts.wmv
Old Jul 9, 2006 | 03:39 PM
user 647483's Avatar
Originally Posted by Cmr0z28
Sounds great!
Old Jul 9, 2006 | 04:34 PM
Cmr0z28's Avatar
Thanks...I just need to straighten out the hangers so my mufflers are even.
eazyZ
Mar 1, 2015 07:12 AM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
stanghunter211
Aug 29, 2002 03:04 AM
Evilfrog
Aug 7, 2002 11:36 PM
Snake Slayer
Jul 26, 2002 06:14 AM
