distributor
Old Nov 30, 2010 | 12:27 PM
chevy25's Avatar
distributor
where is the year location on a LT1 motor because had a problem with switching the ditributor
now the one i hve wont fit
Old Nov 30, 2010 | 12:30 PM
Re: distributor
The year is part of the VIN stamped on the block at the back. See Shoebox's photo. Note proximity to oil filter:
http://shbox.com/1/block_vin.jpg
If your cam has a long dowel pin, and the hole in the timing cover is "large", its a vented (95-97) unit. If the hole in the timing cover is "small" and the inner diameter of the hole in the cam sprocket has "teeth" to engage the Opti driveshaft, its an unvented (93-94) unit.
68camaroboltz
Oct 5, 2015 01:46 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
autoxr166
Sep 25, 2015 04:21 PM
1995Blackz28
Jul 20, 2015 09:34 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
