disconnect MAF = open loop?
Re: disconnect MAF = open loop?
If ive read your question correctly your o2's are already unplugged?. If so then your already running open loop. But if your asking if you unhook the o2's or the maf unplugging either one will put the car in open loop. Unpluggign the maf essentially makes the car run speed density.
Originally Posted by luckyou03
If you unplug the maf while running, the car will die.
I guess my lt1 is different. I unplugged it once while running and it died.
Originally Posted by Z95m6
No it won't. At least not on everyones car i know mine wont and several other guys cars wont. I believe if you unplug the maf your car will still use the O2's. The car goes into speed density mode which relies on the O2's.
Originally Posted by Honda Hunter
Do you really need o2's?
I have a 96. I've unplugged the MAF while running, SES goes off car still runs.
Seems like I'm getting 2 answers here, maybe I'll just unplug both o2's and MAF to get it to speed density. I don't want the car to use 02's.
Brian
Brian
Brian
Brian
The day you tune it in open loop, it will make good power, assuming you get a good tune. The minute something changes - intake, exhaust, etc, the tune will be "off". Back to the dyno for another tuning session. The O2 sensors promote adaptive learning.... the ability to try and control the A/F ratio in response to changes. Delete the O2 sensors and you delete the learning. Have an upset that cuases it to run lean or rich (e.g. - change in fuel pressure) and you can run rich enough to foul the plugs or wash down the cylinder walls with fuel, or lean enough to detonate and damage the internals.
The "learning" isn't perfect, but it does help accomodate change, and prevent problems.
I run open loop, speed-density, but the tune is backed up by more than 40 engine and chassis dyno pulls, and my engine only operates under very specific conditions, nothing is ever changed without checking the tune on a dyno, and the fuel is controlled by taking it out of a drum that I keep in my shed. Not a daily driver, obviously.
carguyshu
Jan 22, 2017 11:19 AM
SMO Q
Feb 11, 2015 07:13 AM
