Disappointing LE2 Dyno #s
Old Mar 21, 2007 | 02:03 AM
  #46
Heatmaker's Avatar
Advanced Member
Dynotune.
Old Mar 21, 2007 | 02:28 AM
  #47
SS RRR's Avatar
Originally Posted by Javier97Z28
Agreed. That's why the first place my car is going to is the track.
And if all goes well, that will finally be today.
Looking forward to seeing the results. Good luck.
Old Mar 21, 2007 | 08:43 AM
  #48
ABA383's Avatar
^^^^^ me, too...Good luck with it today...
--Alan
Old Mar 21, 2007 | 08:46 AM
  #49
Javier97Z28's Avatar
Moderator
Thanks guys, I hope to still make the track... but my freakin' 15x10 Prostars are rubbing still even after caliper grinding last night. I'm going to run home today after work and go nuts with the grinder and see if I can get it to stop. Gonna put me at the track a little later than I like but I should still have time to get a few passes in. Part that sucks is that our track tends to fade pretty fast on test & tune nights, so I won't get ideal traction.
We'll see!
Old Mar 21, 2007 | 09:57 AM
  #50
87bandit's Avatar
We'll see!
did you try cleaning up the inside of the wheel as well? when mine rubbed I had to clean up the slag on the inside of the wheel as well so it would stop rubbing
Old Mar 21, 2007 | 10:19 AM
  #51
Moderator
Bandit, no, I bought them used, but I'll take a look at that today, thanks!
Old Mar 21, 2007 | 10:36 AM
  #52
1SlowFormula's Avatar
This is a serious hijack of the thread but, Javier good luck tonight. I too am looking forward to knowing how you do. PM me the info and a pic if you get one to put up on Frank's site...
Old Mar 21, 2007 | 08:14 PM
  #53
scrmnws6's Avatar
A friend of mine with the LE2 just dynoed 407rwhp through a 9"!
I think whats holding me back is the Granatelli MAF, bad plugs, and bad gas! Cars going in for a tune in April/May.
Old Mar 21, 2007 | 08:29 PM
  #54
Sweetred95ta's Avatar
Good luck Javier (even though you're probably at the track now ). I know this has been a long time comin'.
Old Mar 21, 2007 | 09:06 PM
  #55
brain's Avatar
That original post is a bit old, did Kearn ever get the problems resolved? I agree that revving it past 6K isn't gonna do much good. It peaked at 6K with 352 rwhp. With heads, that's kinda low, don't you guys think? Also, the LE2.2 cam is similar to a 306 or 847, but improved correct? I would figure close to 400 rwhp by 6000 rpms, maybe 6500 at most. My car peaked at 5850 with 358 rwhp. It was over 350 rwhp by 5300 rpms. It also looks a good bit low throughout the chart, I'd say its down by over 20 rwhp at 4K. I know I sound like a broken record, but I'd degree the cam. I've seen too many of these cars make poo poo power for there to be some magic that makes some good and some bad. Its gotta be the install.
Old Mar 23, 2007 | 03:30 PM
  #56
Denny McLain's Avatar
Originally Posted by 2QUIK6
Hey Denny, I've made alot of progress on finding all the gremlins. Had an opti with worn out bearings, was getting all kinds of knock, had a grinding water pump gear, a few restrictive spots in the exhaust, and the stock convertor was slipping some which probably accounts for a large part of it.
I redid the exhaust with all mandrel tubing this winter, fixed the wp gears, found it was still getting alot of knock from the burst knock tables only for whatever reason. I got a wb and got the AFR to 13.1 steady, got a ram air hood/intake so no more restrictive intake duct. And got a nice convertor..its a little loose for my liking for daily driving. IT drives alot better now and has more power, but still haven't made it to the track, will get its first pass April 6th. Hadn't been back to the dyno yet either knowing that I will not stick with this combo due to drivability with the A4. I want to bring the torque back down in the lower rpms and run a tighter convertor.
Good, I'm glad to hear that as I knew there was more in the car. Like you I'm sorting out Gremlins and found the intake gasket leaking, headers leaking, the fuel pressure guage reading wrong and a tiny vacuum leak from a rubber vacuum hose. Think the issue is it takes a lot of time to work these things out and most never do.
Thanks for thinking about me!!
Old Mar 23, 2007 | 03:48 PM
  #57
Originally Posted by scrmnws6
Denny- thats interesting. Just curious then as to why FLP would tell me that to take the 388 hp from the sheet and multiply it by 3% to get my true hp reading... the 1.03 was the correction factor... <--- this is what I was told after I took a glance at the dyno chart for the first time and my jaw dropped as I was expecting around 400 rwhp if not more, and after I was told that I felt a little better.
I do think that the car IS running pig rich, and the car seems to me like it WAS tuned in 3 runs. Ill ask FLP tomorrow what they think about your statement.
I was thinking about having the car re-tuned by FLP or looked over rather, but dont know how much that will run me.
Greg
Pull a couple of your plugs and see if they are black. Most likely NOT the tune and more like an exhaust vacuum leak or bad 02's. I'm a big believer in a routine change of 02's as I've found they should be just part of normal maintance.
You tune for both full power and drivability. Usually you don't have to touch the drivability areas of the charts unless there are issues or things like changing injector size, MAF size, etc. and in your case it's mild enough to not worry about driving tune. The 02 sensors monitor daily driving.
1.03 is 1.03. The dyno always corrects up in hotter weather unless something really strange is going on. SAE is set for a 29.6 barometric pressure and 77 degrees while standard is 29.9.92 and 60 degrees. That's also why standard reads a little higher as it looks at better weather.
Believe you said it was 90 degrees in Chicago which is I think around 700 feet above sea level and would explain exactly why the dyno correct the numbers up. NOT down unless you had very unusual weather conditions. (like unheard of)
I've said this before so I'll make it brief…………. People who hate dyno's.....don't know dyno's. Every major automotive sport except top fuel classes use dyno's and every........EVERY NASCAR team uses a chassis dyno. You guys must know something they don't.
Dyno's are a friend, not a foe and are extremely reliable if you use the same dyno every time. Peak numbers mean a little and it's average hp within the intended rpm that puts the rubber on the road. After a dyno session the first thing I do is plug in the numbers in 100 rpm intervals into a spreadsheet to see what the average hp gain/loss is in each gear of a simulated 1/4th mile run.
Dyno's don't bite, but they may be a bit hard to understand if you're not used to them. So, get used to them.
Old Mar 23, 2007 | 04:06 PM
  #58
[QUOTE=
Greg[/QUOTE]
[QUOTE=Originally Posted by Denny McLain
A guy bought the LE heads and cam that was in a 385ci combo that made 445 rwhp. Today I was helping tune the car and it only made in the high 340 range with again the same heads and cam that made mid 400 range earlier. Now this is an auto so we don't expect it to dyo the same but we knew we were missing something.
The first thing we found was the airbox was overly restricting and by just unhooking the airbox we gained 18 hp. I'd like to try new 02's as that can also throw off peak power. Also the air quality this time of year isn't very good so take that into consideration.
He had the stock 48 mmTB and I'm going to try my spare 58 mm TB to see if that helps. Also I had an electric pump, a welded/ported LT4 intake and every other trick in the book including a year of tuning finding what the car wanted.[/QUOTE]
If anyone can find the optimal tune and combination in just 3 dyno pulls, they are worlds better than I am. When I made 445 rwhp in the 385ci combination mentioned above I was amazed at the people who said it couldn't have happened. Think the real answer is THEY couldn't figure out how or spend the time n effort to make it happen.
Like duh......it only took me a year and probably 150 dyno runs to find what the car wanted sorting out both tune and issues. If you not talented (evidently I'm not) it takes a tremendous amount of tenacity to optimize any car. Just how it works!!
Now is it worth the effort?? Probably not if your the average person, but if you want to hang with the big dogs making the big numbers you got to act like a big dog or be real damn lucky.
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
