Disabling the Traction control?
Old Feb 6, 2005 | 05:01 PM
oneslowz28's Avatar
anyone know how to disable the traction control on a 94 z28?
Old Feb 7, 2005 | 07:08 AM
rskrause's Avatar
Moderator
Re: Disabling the Traction control?
It's really easy, because a '94 does not have it. It was an option from '95 on. Just because you have that lil' "low trac" light doesn't mean anything. Their is no traction control (or ASR as GM called it). If there were, you would have a switch to disable it. Or you could disable it by PCM reprogramming. But since you don't have it, don't worry/be happy.
Rich
Old Oct 21, 2013 | 12:48 PM
cephusbob's Avatar
well something sure as hell is applying the brakes when the tires break loose and pretty much all the time now
Old Oct 21, 2013 | 01:49 PM
You dug up an 8 year old thread and gave absolutely no info to go on. Tell more (including car info) if you really want some help.
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
