Disabling TC lock up?
Old Aug 7, 2004 | 07:50 AM
Formula03's Avatar
If you unplug the converter lock up control module will it cause any trans. problems or drivablity problems? Is there a better way to disable it? Has anyone done this?
Old Aug 7, 2004 | 09:12 AM
sabre81's Avatar
Re: Disabling TC lock up?
You can disable it in tunercat by adjust certain tables. But why?
Old Aug 7, 2004 | 10:21 AM
RamAir95TA's Avatar
You can disable the solenoid by unplugging the wire connector in the valve body. You'll get an SES though.
But as mentioned before, why?
Old Aug 7, 2004 | 03:54 PM
Formula03's Avatar
When I built the motor I also had the trans rebuilt and they put a heavier lock up spring in the car(it helps put less wear on the trans because it locks up faster) well no it acts like it wont unlock itself and it has no stall speed as well. I just want to disconnect it and find out what it does(whether it stalls or not).
Aaront810
Aug 29, 2020 09:34 PM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
z28cam1993
Sep 9, 2015 04:08 AM
