Disabled VATS, now can I...
Old Apr 24, 2003 | 08:51 PM
Mizz96Z28's Avatar
Question Disabled VATS, now can I...
get a regular key made and start the car then take the key out of the ignition without turning the car off like I could in my 3rd gen camaro? Just curious
Myles
Old Apr 24, 2003 | 09:26 PM
93midnightta's Avatar
you could take the key out of your thirdgen becuase the teeth and tumblers were worn down quite a bit. i used to be able to do that in my thirdgen but when i had a new key made i couldn't. being able to pull it out has more to do with age then with the chip on the key.
Old Apr 26, 2003 | 04:26 AM
civic_hunter's Avatar
why an dhow did you disable it?
Old Apr 26, 2003 | 06:57 AM
scoobysnax83's Avatar
if you bypass the vats with resistors (I'm assuming you know how to do this) start the car up and disconnect your little resistor fabrication. The computer will sense a fault in the system and disable it. You'll have a constant Security light until you get the right key pelet or just wire the resistors in permanently.
If you don't know how to do it, check out this website for the resistor values you need to try, if you don't know what your key is.
15 resistor values
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
Aug 7, 2015 08:52 AM
