Dirty Engine
Old Mar 16, 2007 | 10:34 PM
got that 5.7L's Avatar
Dirty Engine
First of all i hope i am putting this in the right forum.. since i bought my car (95 z28) it has about 112k on it and the engine bay is just filthy. i dont know too much about the car yet i am still learning alot about the LT1. i really want to clean everything out so it looks halfway decent. i heard the optispark is a big issue and if i get that wet im screwed..but i dont really have time to pull the whole thing out and wipe it all down...any suggestions on a good way to clean everything out?
Old Mar 16, 2007 | 10:53 PM
Critter's Avatar
welcome to the forums, this is actually in the wrong section tho. it would be better suited for the Show & Shine / Paint & Body Care.
yes the opti DOES NOT LIKE WATER so make sure you don't spray it directly. its located under the rubber intake elbow and behind the water pump. the best way to clean engines that i have seen is to get westly's bleach white (walmart) mix it 50/50 with water spray the engine and let it sit for 45 seconds and spray with a pressure washer. repeat a couple of times if its horribly dirty. and like i said stay off the opti.
Side note don't start hoseing down the engine if it has been running, hot metal and cold water = crack.
Old Mar 16, 2007 | 10:58 PM
Brandon94Z28's Avatar
You guys that spray your engines at all are really brave..
When I had my f-bodies, I used to use a rag and a bucket of water with a bit of dish soap. The tiny nooks and crannies I would use an old toothbrush. Once you get it cleaned the 1st time it is easy to keep up with it.
Brandon
Old Mar 16, 2007 | 11:02 PM
yeah i wasnt really planning on spraying anything in there...probly end up doing the rag and soapy water idea...may take a little longer but it sounds like the safest way
Old Mar 16, 2007 | 11:03 PM
Critter's Avatar
well i was the detail guy for a car lot for a long time and as long as i didn't hit any ignition parts with the water i was always fine. i'm too lazy to do it your way!
i'm sure i've done it over 250 times and have had maybe a couple not start because i hit the distributer. these were not all camaro's tho. i've done it to my car 3 or times with no problems.
Old Mar 16, 2007 | 11:26 PM
ya I am too lazy these days too. Those were the single days Now I don't get time to do that stuff!!
later
Brandon
Old Mar 17, 2007 | 12:08 AM
Z95m6's Avatar
In my opinion people make the opti out to be much worse than it really is. I just recently did a cam install and had an oil leak on the front of the motor. The whole front of my motor, k-member, oil pan, and tranny were covered in oil and crud. I just took it to the car wash today and left the car running. I power washed the whole under side of the car and really focused on the front of the motor and the car never stumbled once. I've washed my motor many other times too. I try not to spray the opti directly but it'll take some abuse if it needs too.
Old Mar 17, 2007 | 12:22 AM
Critter's Avatar
vented are a lot more forgiving from what i have read.
Old Mar 17, 2007 | 12:26 AM
LiENUS's Avatar
I've seen an opti survive 3ft of standing water.
Old Mar 17, 2007 | 02:05 AM
matLT1's Avatar
Original Opti on my Camaro (AFAIK) and still kicking
Old Mar 17, 2007 | 08:23 AM
sbs's Avatar
sbs
I've pressure washed many engines in the last 25 years and never had a problem. On any car you cover the distributor and the alternator beforehand.
On the LT1 since you can't easily cover the distributor just don't spray the front of the engine. Unless you have a Dynaspark in which case spray away.
My own cars get a quick engine rinse with the pressure washer on a low setting about once a month. Old cars I've owned or worked on that were greasy and nasty got liberal application of degreaser plus the pressure washer set on "kill."
Old Mar 17, 2007 | 09:20 AM
ok well maybe i will consider spraying it out..should i add a little bit of soap into the system or just use fresh water?
Old Mar 17, 2007 | 09:26 AM
mdacton's Avatar
I use a sodium hydroxide...and hot water........that will make it alot easier and you will ne less to rinse
Patricklt1
Apr 24, 2015 06:29 AM
BIGCOWL-IMP
Feb 7, 2015 06:10 PM
Sandersen511
Jan 13, 2015 03:49 PM
Timberwolf
Aug 9, 2002 11:24 AM
AL SS590 M6
Jul 20, 2002 01:27 AM
