Dipstick differences and 4 bolt mains
Old Aug 10, 2003 | 09:34 PM
dreamer1q's Avatar
Some of the LT1's came with 4 bolt mains, right? Then what did GM use for a dipstick to clear everything? I have broken 2 dipsticks trying to figure this out. Can someone please help. I have to have this car at Woodward in less then a week, and it wont quit eating dipsticks
Q
Old Aug 10, 2003 | 09:40 PM
gb95zconv's Avatar
I just worked mine in alittle at a time bending it slightly as it went in......push alittle bend alittle push alittle bend alittle. The engine was out of the car when I thought to work it in so that made it easier.
Old Aug 10, 2003 | 09:42 PM
dreamer1q's Avatar
Its not so much getting it in the hole, but they seem to get in the way of the Crank once they are in the hole. We had to cut the orginal tube down to fit, and I broke that messing with the headers. So I went with a Lokar and broke it in one day. The crank took the tip of the dipstick itself off. I'm stumped
Q
Old Aug 10, 2003 | 09:54 PM
gb95zconv's Avatar
I said bend it as you push it in.....it will end up curving into the pan out of the way of the crank....at least I had no problem anyway.
Old Aug 10, 2003 | 09:59 PM
dreamer1q's Avatar
I follow ya now. Thanks, but I am holding out hope that there is a difference in the 4 bolt stick and the 2 bolt stick
Q
Old Aug 11, 2003 | 09:58 AM
gb95zconv's Avatar
Oh ....OK.....but I am using the stocker with 4 bolt mains so it works ....but maybe someone else has another ideal. TTT for ya.
Old Aug 11, 2003 | 11:12 AM
CANTONRACER's Avatar
What oil pan is being used here?
Old Aug 11, 2003 | 11:26 AM
dreamer1q's Avatar
My leaking Canton piece of crap!!!!!
Old Aug 11, 2003 | 12:33 PM
That is probably your problem. I was unable to get my dipstick tube in because of the oil pan being in the way which is also a Canton oil pan. I had to cut my dipstick tube shorter and then run a cut off dipstick with a correct length dipstick in the rear area.
Old Aug 11, 2003 | 01:08 PM
bkrepindy's Avatar
Not to change the subject, but where is your Canton pan leaking? I just installed mine and I am finding that the pipe plug on top of the passenger side kick-out is the culpret of my leak. At least I hope it is the plug and not a weld.
TIA!
Old Aug 11, 2003 | 01:17 PM
BUBBA's Avatar
Yup. I noticed on my new short block 4-bolt main that checking the oil is a bit tricky.
Takes two hands to quide the dip stick back in.
Seems to sit forward more than the stock 2-bolt block.
Old Aug 11, 2003 | 01:28 PM
bkrepindy's Avatar
I have Pro-Gram Engineering splayed 4-bolt caps with a Canton pan. I had to use a tubing cutter to get the dipstick bolted in place. Then I used a pair of pliers to turn the end of the dipstick ~180 degrees. I had to play with it a little but now it works fine.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Mar 13, 2015 11:48 AM
pimpss96
Feb 12, 2015 01:28 PM
97 RedSS
Jun 10, 2003 07:58 PM
