Digital 6 ignition question..
Old Jul 30, 2004 | 09:03 PM
97 RedSS's Avatar
Did ya'll run the negative all the way to the battery or just ground it to thre chassis? Right now I have mine grounded 2 ft away from the ign. box and was just wondering if that would be sufice?
Cody
Old Jul 30, 2004 | 10:49 PM
Re: Digital 6 ignition question..
As long as your battery to chassis ground cable is good, you should not have a problem grounding your box to the chassis.
Old Jul 30, 2004 | 10:57 PM
97 RedSS's Avatar
Im running the ractronix FP wiring kit and it includes the upgraded chassis grnd wire so I think it'll be ok..
Cody
Old Jul 31, 2004 | 01:18 AM
Beast96Z's Avatar
Cody, I had mine done like you are doing and it worked fine. I grounded the box to the left of the radiator shroud where other things are grounded and used the racetronix ground upgrade.
Old Jul 31, 2004 | 01:25 AM
97 RedSS's Avatar
Whats up Jason! Thnks for the response..How are you doing and do you still have your LT1? Im still trying to stay true to the LT1 and not convert although its very hard..
Cody
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
