Is this difficult?
Old Feb 22, 2005 | 04:10 PM
BUBBA's Avatar
Is this difficult?
Thinking about wrenching the crank nut to line the arrow.dot up with 12 o'clock when "6 is at TDC in order to adjust the "5 exhaust RR.
Is this hard to do?
Thanks.
Old Feb 22, 2005 | 04:26 PM
Re: Is this difficult?
Normally it's not a problem as long as you take it slow as compression bleeds off. That way, you won't have to crank so hard and put excess pressure on the bolt.
Old Feb 22, 2005 | 04:27 PM
tamatt27's Avatar
I'm not sure if I'm understanding you correctly, but if you're talking about rotating the crank via the crank nut, to turn the engine to #6 TDC, then no it's not hard to do. Just be sure to turn the crank clockwise, otherwise you'll end up loosening the nut, lol.
Old Feb 22, 2005 | 04:49 PM
BUBBA's Avatar
Thanks much.
Beave2780
Jul 7, 2015 06:36 AM
ad356
Apr 11, 2015 11:12 PM
maybe2fast
Feb 27, 2015 08:09 AM
IgorT.455/406
3rd Gen / L98 Engine Tech
Nov 5, 2002 09:24 AM
70 Cam Guy
Classic Engine Tech
Oct 20, 2002 12:55 PM
