Is this difficult?
Is this difficult?
Thinking about wrenching the crank nut to line the arrow.dot up with 12 o'clock when "6 is at TDC in order to adjust the "5 exhaust RR.
Is this hard to do?
Thanks.
Is this hard to do?
Thanks.
Re: Is this difficult?
I'm not sure if I'm understanding you correctly, but if you're talking about rotating the crank via the crank nut, to turn the engine to #6 TDC, then no it's not hard to do. Just be sure to turn the crank clockwise, otherwise you'll end up loosening the nut, lol.
IgorT.455/406
3rd Gen / L98 Engine Tech
Nov 5, 2002 09:24 AM
