Differential Cover Installed! Need info on Limited Slip Fluid!
Well Since I didn't have a torque wrench to install and torque the cover down to specs I had my shop do it for me. The only thing that I question though is that they used another fluid in stead of the Gm limited slip fluid. They put in Auto X brand limited slip fluid in the rear. I found a really old post saying this stuff works wonders and is great, what do you all think? So far it has made the rear end much smoother and got rid of some of the whine and the clunks i would occasionaly get.
Should I change the fluid to GM Limited slip or will it be fine?
No.Just kidding.Any limited slip stuff sould work I guess,I use the GM stuff,but it all problaby comes out of the same hole.As long as it keeps the clunking down(going around corners),then I would stay with what they put in.Myo2
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
