difference in camaro z28 and camaro ss?
Old Mar 13, 2009 | 12:49 PM
Tanner_94_Z28's Avatar
i have a 94 camaro z28 and i threw a rod in my motor....and i found a camaro ss of the similar year and was wondering if the motors have any major differences or if the motor fit into my car?
Old Mar 13, 2009 | 12:54 PM
whammer33024's Avatar
it will be the same motor
Old Mar 13, 2009 | 12:55 PM
JakeRobb's Avatar
Super Moderator
It'll work just fine. You might have to trade some intake parts, since the SS had ram air (I'm actually not 100% sure that the ram air scoop on the LT1 SS was functional) and the Z28 didn't. Everything else on the engine is the same.
Old Mar 13, 2009 | 02:54 PM
ok im updating u guys the motor is coming out of a 96 ss camaro and i want to know if it will go into a 94 camaro z28 i want to know if i will have to change the computer on the car or will the motor link directly up to the car?
Old Mar 13, 2009 | 02:59 PM
Just use the connections that are already on your car and you will be fine. There will be a sensor or two (crank sensor and EVAP switch) on the 96 that the 94 does not, but there will be no problem.
You will also need the opti harness from the 96, since it has a vented opti (assuming you are getting the opti with it).
Old Mar 13, 2009 | 03:38 PM
CreatiVe2's Avatar
The AIR hose threads are different also (going into manifolds) make sure you keep the 96 engine hoses with those manifolds.
Old Mar 13, 2009 | 05:03 PM
Venomous360's Avatar
Mine has functional Ram air from the factory.
And there are two different motors, one is a 305 HP Motor and one is a 310 HP motor. One was for the SS look and suspension but same old motor and one was for the performance package SS, I have the 305 HP LOOKS package SS with the suspension and HOOD no internal motor Improvments.
Old Mar 13, 2009 | 05:31 PM
As you eventually figured out, there was no SS model until 1996.
Old Mar 16, 2009 | 11:01 AM
ok ill try it out appreciate the info u guys
Brandon Wittmer
Dec 3, 2014 09:28 PM
ChrisFrez
Nov 30, 2014 08:41 AM
grendal
Apr 15, 2010 05:20 PM
Jul 4, 2005 05:00 PM
dreamer1q
Jul 9, 2002 05:37 PM
