difference between stock replacement and comp "r" lifters with cam
Old Sep 20, 2004 | 04:43 PM
dmoor88's Avatar
What's the major difference between a new set of stock replacement lifters and a new set of comp "r" lifters when you're doing a cam install? Are the comp "r"'s supposed to last longer with a bigger cam or what?
Old Sep 20, 2004 | 09:19 PM
mrz28 73/97's Avatar
Re: difference between stock replacement and comp "r" lifters with cam
The Comp R's can handle much more valve spring seat pressure, hence your powerband won't fall like a stone at 5800 rpm. The engine will be able to rev higher before valve float and hp=tq x rpm.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
GigaMp3z
Feb 20, 2003 02:57 PM
mjcent922
Jul 27, 2002 12:42 PM
