difference between cutting a hole in exhaust and..
Old Oct 24, 2003 | 03:38 PM
sabre81's Avatar
installing a cutout. Wouldnt a hole cut out of the exhaust pipe where a cutout would go serve the same purpose? Not that 30 bucks is a lot of money, but its easyer to cut a hole than to remove a section of pipe and weld a cutout in.
thanks
Old Oct 24, 2003 | 03:45 PM
94GrayV6's Avatar
Having a hole in the exhaust would probably be more like an exhaust leak than having an actual cutout. Also, with a cutout you can cap it off when you don't need it open.
Old Oct 25, 2003 | 08:23 AM
Lt1tko5o's Avatar
That might work, but you don't want to run around all the time with that loud exhaust, a cut-out is normally for Saturday night or at the track.
Brian
Old Oct 25, 2003 | 08:55 AM
sabre81's Avatar
Well actually i do always want to run around with a screaming exhaust. i would definitely leave the cutout open all the time if i bought one.
Old Oct 25, 2003 | 09:03 AM
blackbirdta's Avatar
i think that as much as u think you would run with it open all the time you would sometimes wish it were more quiet not to mention you wont pass emissions with your exhaust cut in half...30 bucks is not that much
Old Oct 25, 2003 | 10:25 AM
Mizz96Z28's Avatar
If you want a loud exhaust all the time you might as well just take off your muffler, then when you need to go do emissions just put it back on. I personally wouldn't but thats just me.
Old Oct 25, 2003 | 10:27 AM
sabre81's Avatar
well i do want the performance gain of a cutout as well as the sound, so the muffler thing wont work. i guess ill end up just buying a cutout. now ill have to find someone to put it on for me
Old Oct 25, 2003 | 10:38 AM
Wild1's Avatar
It would be a major exhaust leak. And if you do it before the cat, you may get a MIL illumination. I went with the Off-Road Pipe which works well. Don't forget the police factor.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 5, 2015 07:14 PM
