Difference between 95 and 97 LT1 motor???
Re: Difference between 95 and 97 LT1 motor???
Originally Posted by phoenixLT1
so your running the 97 motor with the 97 computer right? and i just want to say hi to everyone on the boards i just joined in.
But back to the subject
didn't some 95's come with either OBD I or OBD II that the year they swapped over (I believe) contact "Shoebox" he should have the info you need . I believe the major differences are :
crank hub , cam pin length , Opti , crank sensor , timing chain cover .
In all the years of existence of this board, no one has ever documented a factory OBDII '95 V8 F-body. Some say some of the six cylinder models were OBDII.
Originally Posted by ZeeDub
CamaroRob....my car is a 95....with dual cats.....
Or did you change it yourself?Don't forget the 95 3.8s as well. Now I wonder if those were OBD1 or 2?
Always the OBD discussion.
All1995 LT1 f-bodies were OBD-I (w/OBD-II style DLC under the dash). If you have 2 factory cats on your 1995 (California emissions), you are still OBD-I.
1995 3.4 V6 f-bodies were OBD-I
1995 3.8 V6 f-bodies were OBD-II
LEATHAL Z,
The opti is the same 1995-1997.
LEATHAL Z,
Okay this maybe a little off key but I have 95' motor that's getting redone (355). Will I have an issue with using the 97 ecu/pcm? Will I have to run with a single cat or can I still keep duals? I guess I'm a little confused on this.
LEATHAL Z,
LEATHAL Z,
So Shoebox, first thanks for the reply. Second, I plan on having the heads ported and matching cam to go with the bottom end. I'm guessing at that point it will not matter cause a ecu/pcm will need to reprogrammed. Right.
I have a 95 and put in a 97 engine, the only thing I had to do was put the 95 sensor from the block into the 97 engine. The heads on the 97 flow a little better than the 95, but the wall castings are thinner and when ported can warp easier...I ran into that. The solution to the whole cat thing...is just leave them off or hollow them out. I would like to put some cats on, but there just isn't any more clearance officer
I am happy with the swap...I didn't do a whole stock to stock trade, but she definately feels a little faster...heads/intake/cam...etc. I get it dynoed on thursday and can't wait to see the #'s.
1LEThumper
Jul 14, 2003 12:45 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
