Difference between the 93-96 & 97 Rear Main Seal Housing
Old Aug 27, 2016 | 07:38 PM
DSMKilla's Avatar
Anyone know what the difference is between the 93-96 & 97 Rear Main Seal Retainer Housing? For some reason GM lists two different part numbers but I can't figure out what would be the difference between the two. I know they are all one-piece rear main seals so I was thinking that maybe it had something to do with the 97 being OBD-II but it can't be that because the 96 is OBD-II as well.
93-96: 14088556
97: 12554312
Any ideas?
Old Aug 27, 2016 | 07:46 PM
Re: Difference between the 93-96 & 97 Rear Main Seal Housing
I think the later one might be Teflon or something. There is no difference in size.
Old Aug 27, 2016 | 11:22 PM
DSMKilla's Avatar
Hey shoebox, nice to see you're still around.
You're referring to the seal right? I'm talking about the actual housing.
Old Aug 28, 2016 | 09:00 AM
I don't know what the real difference is in the housing. I can't recall anyone talking about it much. Never had a chance to compare the two side by side. Sorry I got off on the seal.
Old Aug 29, 2016 | 07:58 PM
DSMKilla's Avatar
I think you're right about the difference being the seal itself! I was looking at the two different part numbers on Summit Racing and I noticed that when you buy the housing it comes with the seal already installed! And if you look at the picture for the #12554312 (97) you can actually see that housing has a #14088557 (93-96) part number stamped right on the housing.
https://www.summitracing.com/parts/nal-14088556
https://www.summitracing.com/parts/nal-12554312
So indeed it looks like the difference is just the seal itself and not the housing.
Thanks for the help shoebox.
MyShibbyZ28
Mar 3, 2016 08:53 AM
frankrizz
Nov 21, 2015 05:15 PM
one wicked element
Sep 7, 2002 07:28 AM
WOT
Jun 24, 2002 10:38 PM
4ssFed
Jun 11, 2002 06:46 AM
