Difference between 92-93 and 94-97 intakes?
Old Apr 19, 2005 | 10:09 PM
Formula03's Avatar
I was wondering what the difference is (other than the fuel rails being different) between 92-93 and 94-97 intake manifolds?
Old Apr 20, 2005 | 08:05 AM
Formula03's Avatar
Re: Difference between 92-93 and 94-97 intakes?
So, does anyone have any ideas?
Old Apr 20, 2005 | 08:44 AM
zhevy-1's Avatar
On the 93, the fuel lines are a bit different. They don't run over the intake like in the front and back. The 94+ has a groove to accomodate the metal fuel lines, the 93 don't have it.
Old Apr 20, 2005 | 02:36 PM
Stewie's Avatar
Try here
Look at post #3
Old Apr 20, 2005 | 09:51 PM
Formula03's Avatar
That link made no reference to the difference between the 92-93 style and the 94-97 style intake. Like, in my first post I already know the fuel rails are different. What I need to know is there any internal difference between the two? More specifically is there any reason that you couldnt use a 93 intake on a 94-up car and vice versa, given that you run the correct fuel rail?
Old Apr 20, 2005 | 10:02 PM
The fuel rails and some difference in a vacuum port or two. Other than that, I don't think there is any functional difference.
Old Apr 20, 2005 | 10:05 PM
Formula03's Avatar
Well, I have a chance to buy a ported 93 for a good price and I was planning on running custom fuel rails, I just want to make sure this will work before I I spend the money. They take a different throttle body, so does that mean the IAC is different?
Old Apr 20, 2005 | 10:14 PM
Yes the IAC is different on a 1993. You don't have to use a 1993 TB, though. I thought the discuussion was just about the intake.
Old Apr 20, 2005 | 10:39 PM
Formula03's Avatar
My main concern is the little passages in the runners, I really dont know what they are or do but I figure they are important and I was wondering if they are cast in the early model?
beaver50
Feb 15, 2015 02:56 PM
ModdedNerd
Jan 29, 2015 07:23 PM
lt1-xjs
Jan 17, 2015 07:52 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
