Difference between 1994 and 1996
Old Oct 18, 2005 | 11:50 PM
rhas91080's Avatar
Is there a difference between the 1994 and 1996 lt1 heads?
Old Oct 19, 2005 | 12:13 AM
MachinistOne's Avatar
Re: Difference between 1994 and 1996
1996 heads are most likely the #561 thin wall castings.
Old Oct 19, 2005 | 01:00 AM
rhas91080's Avatar
so there is nothing like different sensors or anything major. what i want to do is take camaro 1994 heads and bolt on my impala 1996. the heads are comming off my 1994 z28.
Old Oct 19, 2005 | 03:11 AM
sssalah's Avatar
They will bolt right up.
Old Oct 20, 2005 | 06:49 PM
Ultra_Dog's Avatar
Not sure if the Reverse Cooling heads are applicable to this issue or not?
Old Oct 20, 2005 | 11:08 PM
B-body heads are cast iron. F-body heads are aluminum. Either will bolt up. You may have to reposition the temp sensor where you need it.
Old Oct 21, 2005 | 12:20 AM
rhas91080's Avatar
thanks
i just won a set of lt1 heads on ebay for 225.00
i plan on porting them a little myself. it will be my frist time porting job but i got my dad overlooking my work. i am also going to get 2.00 or 2.02 intake and 1.55 exhaust. the heads are going on my 1994 camaro and the head on my camaro will have the same work done to them as well and will be puting hem on my 1996 impala.
Red Hawk 94
Mar 18, 2019 04:03 PM
titanthomas
Apr 18, 2015 11:44 PM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
