Difference between 15" rims and 17's
Old Sep 12, 2003 | 02:13 AM
S.J.S.'s Avatar
Anyone ever document the difference in 1/4 mi. times when using 17" rims then throwing on 15's? I was just curious as to the gains when using the 15's.
Old Sep 12, 2003 | 02:35 AM
revtime's Avatar
If overall tire diameter stays the same and weight stays the same then there will be little difference.
The reason to go to 15s would be weight and traction to an extent cause the taller sidewall (keeping the same tire diameter) should give you better traction.
Basically, 15s are lighter (racing wheels, bogart, weld,etc) and you can run a taller sidewall so you get better traction.
Hard to say what made how much difference, skinnies up front will help and the traction out back will help, I would say 2 to 3 tenths.
Just guessing though.
Old Sep 12, 2003 | 02:40 AM
5.0THIS's Avatar
When I went from stock shooters with 245/50-16 rubber to 17x9.5s with 275/40-17 rubber, I noticed a difference in the car, not to mention I weighed the 17x9s and there was a fairly significant ( considering it is unsprung rotating mass) difference in weight.
Old Sep 12, 2003 | 07:30 AM
OldSStroker's Avatar
A typical 15 inch wheel and tire, even with the same diameter as a 17 combo has less rotating inertia, the resistance to being accelerated or spun up. It may also weigh a little less. Larger wheels with lower section tires tend to concentrate the mass farther from center which increases rotating inertia. I often wonder how the little ricer cars with 19 inch wheels can safely pass in traffic.
The engine not only has to accelerate the mass of the car, but it has to spin the wheels/tires up to speed also, as well as all the drivetrain parts.
Plagerizing from Herb Adam's book Chassis Engineering:
Just removing 16 lbs from the body/chassis would have a very small effect in et and mph. Removing 4 lbs from each wheel and tire would have about 3 times the gain, and removing the 16 lbs from things turning at engine speed would have perhaps 15 times the gain as just removing the weight. In other words, if 16 lbs. from the body equated to a 2 hp. gain, removing it from the wheels would equal a 6 hp gain, and removing it from the rotating parts at engine rpm would be an equivalent 32 hp gain during maximum acceleration.
When lookin for 1/4 mile time differences, you should compare rotating inertia, not just weights, and you should run back-to-back on the same day. The faster the car, the bigger the difference.
Old Sep 12, 2003 | 09:16 AM
IrocManiac's Avatar
Thats good stuff...I had heard that before but didn't know where it was from.
Quickss96
Jan 29, 2016 05:56 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Deane
Aug 27, 2015 06:29 PM
Cbr02
Aug 24, 2015 07:12 AM
whitehooptie
Aug 10, 2015 07:02 AM
