difference in 1/4 between 3.42 and 3.73?
Old May 27, 2004 | 08:47 AM
"White Knight"'s Avatar
I have been debating on which gear to go with for a very long time now. I wan't the pull but not sure if i want to run too high of rpms when crusing around on the freeway. So i was wondering what your guys' guess is on how much of a 1/4 diff you would see between the two gears? O yea and i refuse to put a roll-bar in this car so once i hit 11's......i will have to start letting off early So i am thinking i should gear this more for the street rather than drag.......but i want the hard pull of 3.73's too This isn't a daily driver either.
Old May 27, 2004 | 09:07 AM
Red95M6Z28's Avatar
If you have 3:23 now going to a 3.42 would be useless. A 3:73 would be better but I went from 2:73 to 4:10 in my A4 and I LOVED it! I had a stock stall with no shift kit and it was still a blast to drive. I only turned around 2500 at 65mph in over drive.
Old May 27, 2004 | 09:45 AM
BadAssed93Z's Avatar
i droped 4 tenths going from 3:23's to 3:73's.
dont know about 3:42's though
Old May 27, 2004 | 10:24 AM
street demon2k3's Avatar
i been waiting to do gears on my 93 but i just wanted to know how much of a difference it would make. guess on my next check im doing 3.73's. did you guys buy just the gears or did you guys need to buy a kit with some other stuff included?oh and BTW 93Z did you need to change the gears in the tranny tailshaft(correct me if im wrong)?
no hijacking intended
Old May 27, 2004 | 11:36 AM
Red95M6Z28's Avatar
Gear install kits make things much nicer and replace some of the worn parts. I would strongly recommend a rear girdle cover. They strengthen the rear and significantly.
Xiantyl
Jul 21, 2015 05:42 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
SergheiS
Jul 5, 2015 03:27 AM
MustangEater82
19
Sep 3, 2002 02:09 PM
