Didn't use anti-seize on header bolts....
Old Jun 19, 2005 | 02:50 PM
fredmr39's Avatar
How many others haven't and how many have then had problems? This install was back in January w/ ARP bolts. I don't know why I did not but did on plugs...I think I was thinking how some people have plugs back out from anti-seize, and I ddin't want to chance header bolts backing out...
Old Jun 19, 2005 | 03:11 PM
salty's Avatar
Re: Didn't use anti-seize on header bolts....
I'm about to install headers this week, so I've been doing a a lot of searches for install info. It seems that some broken header bolts can only be removed by pulling the head b/c of access issues . Without anti seize you run the risk of that happening. I'm planning on using it and checking the tightness of the bolts periodically.
Might give you peace of mind if you took them out one at a time and put the stuff on now...just a thought.
Old Jun 19, 2005 | 03:19 PM
fredmr39's Avatar
How long before they are welded in do you think? I was thinking of pulling one by one now, but if I were to break a bolt in there now, that would be bad!
Old Jun 19, 2005 | 03:37 PM
salty's Avatar
I would imagine it would take longer than 5 months, but who knows. Have you ever checked them for tightness? the ARP are supposed to be good bolts, and they should be stronger than the old stock ones that I've read about people breaking.
I think more often the problem with header bolts is backing out, rather than seizing up.
Old Jun 19, 2005 | 03:59 PM
fredmr39's Avatar
Yes I check for tightness often, never backed out, but if I try loosening they come out no problem... might as well throw some anti-seize on all I can get out (access to one is poor).
Old Jun 20, 2005 | 01:35 AM
1racerdude's Avatar
Anti-seize on plugs won't cause them to back out if they are tightened right in the first place.
Get some Bersline locking bolts and put anti-seize on them and lock them in,problem gone forever.
Old Jun 20, 2005 | 01:52 AM
mr_will's Avatar
i put anti seize on every bolt i mess with
or locktight depending on the bolt or screw im messing with
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
geinsteder
Exhaust System
Apr 20, 2015 04:23 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
