It didn't start this morning...
Old Dec 4, 2006 | 07:21 AM
19z28camaro02's Avatar
Exclamation It didn't start this morning...
So i was driving home from work last night and all of a sudden, the tachometer and the speedometer died and the SES Started to flash. 2 seconds later, everything returned to normal. I go to start my car to warm it up this morning, because its 11 degrees, it purrs. I turn to leave the garage, get to the door, and i heard it die. I climbed in and tried to get it to fire, nada. WTF? Are they related????
Old Dec 4, 2006 | 07:41 AM
Sweetred95ta's Avatar
Did it turn over (crank) when you tried restarting it? Sounds like you may have a loose ground somewhere. Here's a link for non-starting LT1's.
http://www.mainstreamtopics.com/foru...p?showtopic=78
Old Dec 4, 2006 | 07:45 AM
it cranked, but it just wouldnt turn over
Old Dec 4, 2006 | 08:07 AM
which ground? where? this is like the worst week of my life, and its only monday...
Old Dec 4, 2006 | 08:23 AM
Well, since you said the speedo and tach died and the SES light flashed, I'd say that something electrical was going on. Did you get the car scanned to see what the code was? There is a PCM ground on the passanger side of the oil pan, a ground strap on the coil bracket bolt, ground on the passanger side motor mount (wouldn't keep the car from running), and there may be others. Get the SES light checked and check all the grounds and make sure they are grounded. I hate electrical gremlins.
Old Dec 4, 2006 | 08:43 AM
the SES only flashed for a second while i was driving, it didnt stay lit for me to get scanned.
Old Dec 4, 2006 | 08:54 AM
Doesn't have to stay lit. The PCM stores the code for a period of time.
Old Dec 4, 2006 | 09:59 AM
Chevycobb's Avatar
just take it to autozone and have them pull the code for ya. no charge.
Old Dec 4, 2006 | 10:05 AM
It won't start.
Old Dec 4, 2006 | 10:09 AM
Chevycobb's Avatar
maybe you can rent one if you dont want to have it towed last time that happened to me with the tach and speedometer it was a bad alternator and caused my gauges to go crazy when my headlights or something else would be turned on. like what was said...check all grounds and check the back of the alternator and make sure that cable didn't come loose
Edit: can anything turn on? headlights, stereo, etc?
Old Dec 4, 2006 | 10:19 AM
That's why I asked him about the car cranking after it died. If the battery wore down enough to not run the car, it wouldn't crank (or it would be very slow) immediately after it died. The alternator was the first thing that came to mind as well.
Old Dec 4, 2006 | 12:25 PM
hektyk's Avatar
Mine is having the same sort of problem. It stumbles and dies alot. Sometimes it won't start at all unless I keep cranking and have it floored. My mechanic says he thinks it's the PCM which is tuned. I got some codes for you guys though. 51 and either 36 or 32. can't remember exactly if it was 32 or 36. It's been down for months though and it's killing me. I replaced the whole ignition by the way, the cap rotor distributor coil and ECM. I dunno! I'll drive it sometimes and it will run fine for a while then just die.
Oncomingstorm22
Jan 22, 2015 07:15 PM
Deadbolt24
Jan 19, 2015 01:29 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
tds1213
Nov 27, 2014 12:55 PM
Darth Xed
Sep 4, 2002 12:56 PM
