View Poll Results: Did you sping a bearing after cam install??
Yes, it sucked and am now dreaming about 383's
24.62%
No, in fact, I fired it up while heading to the track...
75.38%
Voters: 65. You may not vote on this poll
Did you spin a bearing or not after cam install??
Old Nov 10, 2006 | 10:48 PM
johnny3986's Avatar
Well, its coming to be my "Camshaft Awakening" and I'm starting to have the nail biting worries about spinning.
I have worked on cars since I was 14, and am not afraid of the install, but a lil anxious about the unknowns. I have rebuilt RX-7 13B motors before, but never a piston engine and this will be my first time tearing one...err...laying one open.
I have read posts labeled "Post here if you did spin" and "post here if you didn't spin" but all I have come up with "be clean, and the rest is to chance"
I know to be super clean, and I will be following shoebox's write-up to the T, but this might helpmy apprehensiveness.
Old Nov 10, 2006 | 10:55 PM
KillinFormula's Avatar
a friend of mine did
Old Nov 10, 2006 | 11:10 PM
This poll has been done.
http://64.65.63.61/forums/showthread.php?t=322170
Old Nov 10, 2006 | 11:18 PM
CamaroSS30thAnn's Avatar
i have not , but the again i only spin to 6200 ish although it has seen 6500 a few times
ppl spin alot higher than that and thats when they usually spin a bearing
Old Nov 10, 2006 | 11:25 PM
ibanez6rg's Avatar
Negative, Ghost Rider.
Old Nov 11, 2006 | 12:04 AM
bombebomb's Avatar
Id say cam it, what the worst that could happen?
Old Nov 11, 2006 | 12:08 AM
Dennis93TA's Avatar
put in a gm847 cam on 92,xxx now have 94xxx and nothing yet. Even broke it in in oil that had been in the car for about 1500 miles.
Old Nov 11, 2006 | 09:10 AM
Z-RATED94's Avatar
Knock on wood, so far so good. Shift points set at 6400. And can say it won't spin one for at least 5 more months. It's sleeping in the garage till spring.
Old Nov 11, 2006 | 09:43 AM
My Iroc Z28's Avatar
Im still good with my 847 spinning it to 6800 @ the track.
Old Nov 11, 2006 | 01:14 PM
Clean97Z's Avatar
I did but it was from running it with sticky tires and higher speeds at a local roadcourse. I think if I would have put the money into the canton road race pan and a high volume pump up front the problem never would have happened. It is fixed now and has seen two track days since then and it is perfectly fine.
Looking back I would defintely do this again, I would put the money into the pan and pump up front though.
Old Nov 11, 2006 | 01:31 PM
scrmnws6's Avatar
Not yet!
Old Nov 11, 2006 | 01:44 PM
93yellowta's Avatar
put cam and other mods in at 150,000 so far up to 160,000 and running great, but I set my rev. limiter to 6200 rpm's. to hold off on a rebuild...
Old Nov 11, 2006 | 02:49 PM
johnny3986's Avatar
Originally Posted by shoebox
Whoops... sorry I searched, but didn't come up with this post I guess.
I search before I post most times and try not to repeat. Thanks for the point in the right direction though Shoebox. You came through again.
That post was started in 2004 so I guess a recent one wouldn't hurt...even though it is redundant to some though.
Last edited by johnny3986; Nov 11, 2006 at 02:57 PM. Reason: Added in thanks to Shoebox
Old Nov 11, 2006 | 04:49 PM
rob97ss's Avatar
You forgot option C in your poll,Yes i spun a bearing now Im enjoying my 383.....LOL
Old Nov 11, 2006 | 04:56 PM
aboatguy's Avatar
What about option D: I've been beating the stock short block like a Two dollar mule and the D@mn thing just won't break?
Mike
