did opti plugs and wires still stutters and surges?
Originally posted by 1965GP
My 95 just started doing this today after driving in an extreme thunderstorm. Anyone ever have any problems with water getting in the Ram Air set up? I thought it could be the opti/msd but it is pretty coincidental that it happened right after the storm. any suggestions?
I've replaced everything mentioned in this thread so far except the MAF and the ECM, and I mean everything.
The one thing that I did that seemed to fix all my problems was to replace the ground lug for the ECM and clean all the ground terminals that connect to it.
The reason that it needs to be replaced is that it screws in to the passinger-side inner-fenderwell and is exposed to rain and moisture which corodes it.
In order to properly clean the stud you have to screw the lug out of the body and clean it though, not just clean the top part of the stud.
Originally posted by Carlos93Z
New Opti
New plugs & MSD blaster coil/MSD wires.
New O2 sensors.
New chip(93).
IAC valve cleaned out & fully functional.
No codes being thrown.
New Opti
New O2 sensors.
New chip(93).
Originally posted by Brettinator
I've done D all the above except cleaning the IAC. I'll do that today. ThrotBod was cleaned, etc but I didn't do the IAC. will try that this evening, thanks. I'll post any findings.
There's a gasket that you have to get, the dealer may have it in stock, once you take off the TB, the IAC assembly is attached via 7 star bolts??? Unbolt that, the IAC assembly with the gasket comes off, you'll have to scrape off the remaining part of the gasket in order to install the new one. The IAC will probably be BLACK, use TB cleaner & a toothbrush to clean it all out, will have heavy carbon deposits. May take some time to scrub it all out, do NOT try to push the spring assembly, leave it as is, then put it back together & let me know what happens.
Hey Carlos, do you know of any websites that would have some pics of the IAT assembly? I did clean my throttle body with seafoam but I just sprayed it inside throttle body. I want to try anything I can to figure this one out?
Thanks,
Rich
Thanks,
Rich
Its me again : ), I forgot to ask everyone with this low RPM stumble. Does your car throw a misfire code? Mine throws a multiple misfire code and I was wondering if that could help me narrow something down? Again all help is greatly appreciated. Thanks,
Rich
Rich
What is the ECM? I have cleaned and fixed everything you can think of, the only thing i havnt tried is someone said sumthing about an ECM earlier in this post, thats the only thing i havent touched. BTW the ICM did nothing when I replaced it. I mine as well go back in time and buy a new 95Z. anyone else feel like they want to run there car into a lake?
Thanks,
Rich
Thanks,
Rich
First things first, you will have to get at least TWO new gaskets, there is actually 4 gaskets that you can buy, I think it's called the throttle body rebuild kit--yeah right, just 4 gaskets...
Anyway, one is for the TB, one is for that plastic plate that sits above the TB??? The third is the gasket that the IAC assembly bolts on to the the bottom of the TB, and the last is a little circular gasket for the actual IAC valve. I took apart everything except the IAC valve, I kept it in, and still did a heck of a job cleaning it.
This gasket kit cost me $42.00 American & change from the dealer, the dealership had it for me by the end of the day, hopefully some other dealership has this kit for you.
To take off the TB, first things first, if you do not have a Haynes or Chilton's manual, go buy one NOW, they have pics showing how to remove the TB, including the throttle cable, it's pretty easy!
DO NOT SOAK THE THROTTLEBODY/IAC ASSEMBLY!
Don't ask me why, somebody told me not to, it may damage something, I just sprayed it with STP TB cleaner & scrubbed the **** out of it, came out pretty darn clean I might say. It took me 3 hours total, I'm sure it would take me half that time now. It's not difficult.
Man I cant believe how many people have this same problem and dont seem to find the fix! !
Rich T
Rich T
if i'm stopped & put the car in park she wont do it though. Thoughif I do the fan switch mod and keep her cool it will solve the problem.
Is everyone elses car only doing this while running hot?
Originally posted by Stormman
Add me to the list, mine happens only after temp reaches 220, like when the fans should come on. Only when shes hot, flat on thrttle then kickes in hard, at at a stop low rpm the surges hard.
I FINALLY HAVE MY CAR BACK!
When my stumble began it was right after a header install so I figured it was related...kind of? I think my EGR was partially clogged up and when I lost backpressure from the headers, it just wouldnt work enough. After replacing the EGR , that code went away but the stumble stayed and an 02 code popped up? I had the 02 replaced but still had the code?? After awhile of driving me nuts I took it back in and had ANOTHER 02 put in.....WALLA! Stumble has been gone for a week and a half so far and no code from the 02. So I think that the EGR was the original cause and then a header leak caused an 02 to go and caused the same symptom. I guess when I replaced it the 2nd time it was just defective or something. Now I just need to get rid of the damn AIR light.
Right now though its ok, shes running good again
I hope everyone gets theirs figured out because its a great feeling after 8 months!Thanks to everyones input throughout!
Rich
Mine has most of these symptoms since my header install, I get a multiple misfire code along with bad 02's.. i'm going to replace the 02's since they're crap. my car will stumble real bad after about 2 to 3 minutes of driving it and go away and be fine for the rest of the day.
